StirCrazy
Jan 16, 2022Moderator
3 tons wrote:
Stircrazy said, “if the battery comes with it and it actavates it totaly kills the battery.”…How so??
A quick check over at LifeBlue dispels this notion:
http://www.lifebluebattery.com/rv-boat-low-temperature-lithium-ion-batteries/100ah-d-lt-lithium-battery.html
Same thing at Renogy:
https://www.renogy.com/12v-200ah-lithium-iron-phosphate-battery-w-bluetooth/
3 tons
doesn't dispell it at all. they are just heating the battery befor it ever gets to 0 degrees. what I was talking about was just cutting off charge sources at around 0 (sorry 32 for you guys) and allowing the battery to still be used untill say -20C (not sure what that is in F this early -17 or somthing like that) just running a load like a furnace at that temp should be enought to keep the internal temp of the battery above 0c which would allow charging again.
Steve
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
