Que tal Chris. Your previous fridges may have been smaller as well. 3 way fridges are still available but only in smaller sizes. They are usually found in truck campers and very small trailers. An absorption fridge uses one of three sources for heat if it is a three way. A 12 volt element, (uses a lot of power) an AC element (usually around 4 amps at 120 volts or 40 amps at 12 volts through an inverter) or a small propane flame. A two way fridge simply drops the DC electric element.
You can get a larger 12 volt fridge but it will be a compressor type fridge, quite often with a Dan Foss compressor. Dometic makes them and they usually use around 4 to 5 amps DC at 12 volts when cycled on. Much less power than the RV absorption fridges. Equivalent to about 4 or 5 light bulbs. I would recommend a robust solar system (400 to 500 watts) and at least two 6 volt batteries if going this route. We will be doing this in our little rig when the dometic dies. It is on its last legs but hanging in there.
Hasta la proxima amigo.
