- sjholtExplorerIf it was mine, I would smear a light coat of RTV on the none sticking surface as additional insurance. I did say if it was mine.
- SoundGuyExplorer
It's your rig, you can do anything you want with it but no A/C manufacturer recommends the use of any sealant, just a properly torqued rubber seal affixed to the underside of the top unit. The only "additional insurance" required is periodically checking to make sure those four bolts securing the top unit in place are properly torqued, which I think is the message many in this discussion have been trying to relay to the OP. ;) - Chris_BryantExplorer IIThe trouble with using a sealant is that the gaskets are expendable- they will need replacing at some point. If the gasket is sealed to the roof, you've added a huge amount of time to the job- getting the roof clean and smooth.
- deandecExplorer
This I learned, but the old gaskets did last 20 years before the refrigerant blew out......
Installed the new AC without sealant although I will not last as long as the old gaskets did.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
