tarnoldExplorerFeb 13, 2017What size fuseGoing to add a 1000 watt pure sine wave inverter. Want to install a ANL fuse between inverter and battery. What size fuse should I use? Will be nothing more than Cpap machine or tv.
time2rollNomadFeb 13, 2017Assuming #4 or #2 wire I would be about 125 to 150 amps.If you are going smaller on the wire the fuse would need to be reduced.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 07, 2026
