Going to add a 1000 watt pure sine wave inverter. Want to install a ANL fuse between inverter and battery. What size fuse should I use? Will be nothing more than Cpap machine or tv.
If you are connecting to 12V for the inverter, just go ahead and put in a 12V power point for the CPAP if yours will run on 12V. If it will, its a bit redundant to convert 12v up to 110, then turn around and convert it back to 12v for the CPAP. Wasting power each way. But having power for a TV is good, as 12v TVs are a bit harder to come by, and sometimes create other problems also.
