Going to add a 1000 watt pure sine wave inverter. Want to install a ANL fuse between inverter and battery. What size fuse should I use? Will be nothing more than Cpap machine or tv.
1000 amp inverter doesn't tell me much. Is 1000 continuous or surge? Make and model would help! Your light load, you could get by with your listed wire size of #4 or #2. Fuse for around 60 amp. You would not need an ANL fuse for that size.
