Going to add a 1000 watt pure sine wave inverter. Want to install a ANL fuse between inverter and battery. What size fuse should I use? Will be nothing more than Cpap machine or tv.
My cheaper PSW inverter (Canadian tire brand) seems to be hypersensitive to low voltage. I originally wired it with 2 AWG welding wire but recently re-wired it with 2/0. I used a 125amp circuit breaker, I like to use a circuit breaker so that it can be used as a switch as well. The 2/0 seemed to solve the low voltage issue but if I would have realized how difficult that wire is to deal with I may not have went that large.
