tarnoldExplorerFeb 13, 2017What size fuseGoing to add a 1000 watt pure sine wave inverter. Want to install a ANL fuse between inverter and battery. What size fuse should I use? Will be nothing more than Cpap machine or tv.
pianotunaNomad IIIFeb 13, 2017Fuse as close to the battery bank as humanly possible. Fuse to the wire size. Use big wire with the shortest possible run to the inverter.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 07, 2026
