wa8yxm
Mar 14, 2022Explorer III
Inverters. be they MSW or PSW/TSW run around 85-90% efficient (Varies slightly model to model) so if you are putting out 1800 watts you are drawing about 2,000
So calculate the maximum load.. Add a bit for safety (I'd use at least a 2,000 inverter or a 1500 watt load) Figure motors may need as much as 5 times their rated wattage for starting (Or more in some cases)
That about covers it. 2,000 watt is what I used. Microwave OR coffee maker plus television/radio and a few tiny loads like LED night light or clock. .
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
