daystrom's avatar
daystrom
What sort of sealant is this?
Found on various parts of my trailer where a thick bead is necessary like between the skin and door or the skin and the slide out seal. Here is a pic of the later:
Almost feels like a silicone rubber, not your typical ProFlex.
Lap Sealant?
  • ernie1 wrote:
    PleasureWay uses a product called "Sikaflex" that looks like that. Not sticky and sorta pliable.
    Yeah, ProFlex would also fit the description, but both of them apply as a caulk and I'd be shocked to see it used behind trim pieces that are screwed or clamped against the sealant. I am definitely interested in the answer.
  • PleasureWay uses a product called "Sikaflex" that looks like that. Not sticky and sorta pliable.
  • It sure doesn't feel like putty tape. This is definitely some type of rubber sealant. The putty tape I have used is tacky and attracts dirt. This stuff doesn't do either.
  • Butyl putty sealant is what I have always seen used on the exterior of an RV
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
