grodnay's avatar
grodnay
What to do with an 1991 Jamboree chasis AC with R12?
Hi all!
Just bought this RV. The chasis AC does not cool. The compressor does not start. I can tell that this AC runs on R12 by the refill connection type. A workshop suggested a conversion to R134 for $550. They replace the also the dryer and accumulator.
What are my options?
Thanks,
-Guy
  • There is a drop in replacement for R12. It's called Freeze 12. I used it in vintage cars so I didn't need to increase the condenser size. It cools great.
  • I don't market for anyone, but 1-800-radiator has a kit I used personally on my VW. It comes with everything. The compressor, dryer, condenser, hoses, o-rings, and the all the little parts. All I did was install everything, get it vacuumed down, and pumped up. Worked like a charm. Good luck
  • If they are replacing the compressor and converting to 134,that is as good as it gets. Soooo,it depends on what the story is on the compressor. If a fuse is blown or clutch not ingaging,$500+ is pretty expensive just to convert.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
