ScottG wrote:
The 9280 would help but you couldn't use your eu1000i to run it because it would be badly overloaded. Even you 9260 is a stretch for it at times.
Oh yah, you don't have to tell me the EU1000i is a stretch, If the batts are deeply discharged the EU100i will not handel it.
Just wondering how much amps I can pump into these batteries.
Prior poster was asking where the batteries are. I have a battery compartment on the curbside, last compartment back. I have a pull out try with 4 Sam's Club golf cart batteries. Very thick cables running to batteries. I need to take a closer look at ther PD, located under the bed. I can't recall the wire size from converter to batteries.
Thanks for the info so far.
