2oldman
May 02, 2016Explorer II
As said, get a PSW. Newer technology is going to present problems with MSW. Outback is top of the line, GoPower and Samlex are pretty good too.
To power the entire coach with my Prosine I intercepted the shore power's connection to the panel feed line at a jct box just inside the basement where the shore power arrived, and spliced the inverter 120v input to the shore cord, then the inverter's 120vac output splices into the panel feed line. That worked wonderfully for 10 years.
If you have enough battery (4 at least) to run a coffee maker you should be able to handle the MW.
I did my own install.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
