Ductape
Aug 20, 2015Explorer
Here's how you can figure it out.
Turn everything off and let the batteries rest for 12 hours or so. NOT at full charge with a surface charge on them, but at 70% or so; wherever in the range you think you'll typically operate. Take the voltage. That's your true state of charge voltage.
Turn on the fridge and other normal parasites like propane detectors. Check voltage again. Now you know what the difference is between resting voltage and idling voltage.
Do it again with the water pump or furnace on and now you'll get some eye opening info on the voltage sag with a real load on.
Now with that you can easily do the math. So using Oldmans's 12.1 above as an example: if the idling load drops you .05 the 50% SOC with idling load is 12.05.
If the furnace drops you .2 volts then 50% with parasites and furnace is 11.85. Easy peasy.
Having RV issues? Connect with others who have been in your shoes.24,368 PostsLatest Activity: Mar 11, 2026
