mikestock's avatar
mikestock
What you need to know if you buy a macerator
What you need to keep in mind is that the 3" dump hose and connections must be in tip-top shape. Your standard dump hose usually sees only negative pressure as the outlet is normally below below the rv outlet. Your inlet to the macerator and 3/4" hose is not fast enough to create a negative pressure. Your 3" entry hose may see a significant positive pressure, depending on how full the tank is.
I would test out the hookup with a gray water tank outlet before going live with the bad stuff. I learned this the hard way but managed to minimize the damage and shut the valve quickly. It is still wise to never walk away while it is macerating. S... happens at any time.
  • If possible, connect the macerator directly to the RV sewage pipe without a flexible hose.
  • Agree. We have a heavy duty reinforced, but still stay while it is running. We also use a dedicated "wash out" hose for it.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 26, 2025
