timmac
Feb 14, 2015Explorer
jrnymn7 wrote:
If your Vbatt did actually drop .13v, from just 20 seconds of microwave use, then that's a loss of about 22 Ah's on a 200Ah bank. That seems highly unlikely, seeing as 1600w/120v = 13.33a x 10 = 133Ah's per hour x .00555 hours = 0.74Ah's.
... So it was definitely surface charge being burned off.
Yes maybe I should have let the surface charge settle down, I do believe my new batts sit at about 12.90 after surface charge is done, it has a 85 watt solar panel that keeps it at this voltage.
I even think now it might have read 13 volts on tester at time of micro wave testing, I was not really looking at that was just checking how low the batts go during micro use and checking to see if any voltage loss between batts and inverter.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
