jrnymn7
Feb 14, 2015Explorer
Voltage Drop Calculator
... scroll down for calculator
Cheapo terminal rings could also be adding to voltage drop, as well as any circuit breakers in the circuit. This is why you must compare Vbatt with Vinput at inverter, while under load, to determine how much voltage drop there is. Keep in mind, as current (amps) goes up, so does voltage drop; whether charging or discharging.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
