TLLOYD's avatar
TLLOYD
Whats so special about Onan generator oil
Just doing a service on my generator (5500 Marquis model 5.5HGJAB-1038D). Bought plugs and filter, but they wanted $15 a quart for the Onan SAE 15W-40. Thought maybe I could just get it cheaper at an auto parts store and not have to get the Onan brand.
I noticed I have an open bottle of OnaMax SAE 30 in my garage which was probably for my old 4K generator.
Question is can I use an oil other than Onan? I don't feel like driving all the way back to Camping World to buy 2 quarts, but will if that is what I should use.
Auto parts store did not have non detergent 15W-40, but hat 30W. They do have 15W-40 that is not detergent free. I don't known if that even makes a difference.
Thanks
  • You do not want non-detergent oil in an engine, the detergents break down the combustion byproducts and keep them suspended. Save it for the pressure washer pump. It also does not come as a multi weight,any of those will be a detergent type.
    Any 15-40 will be just fine as long as it is the correct weight and meets the specified API service classification. The OEM's make big money rebranding oil as you have discovered.
  • I have been using a good quality oil for years, with no trouble. I think changing it at least once per year with the filter, and run it loaded once a month, will give you the best service.
Having RV issues? Connect with others who have been in your shoes.24,335 PostsLatest Activity: Nov 14, 2025
