QCMan
Jun 14, 2021Nomad III
DS Canuck wrote:
The good news is that the pink stuff you used is non toxic and will eventually become so diluted it will not be noticeable!
I no longer use antifreeze ,I just drain everything and blow the lines out with compressed air!
A compact tire inflator works fine !
I have used the same method to clear our Lawn sprinkler system and drain the water from our home plumbing when taking a winter vacation!
^^^^^x2
If you are methodical and get each system blown out, dewinterizing just entails putting the caps on the low point drains, closing the fresh water tank drain, replacing the plug/anode in the water heater and running the water in the hot and cold lines until they run without sputtering. If you use the fresh tank for drinking you may want to sanitize it.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
