dougrainer
Jun 15, 2021Nomad
Lantley wrote:Sjm9911 wrote:LouLawrence wrote:
Don't use anti-freeze next time. Drain the fresh water tank, and black and grey tanks. Use an air compressor to blow the fresh water lines and then just throw a bit of anti-freeze in the P-traps to get rid of or dilute the water enough to prevent freezing. Next year you are good to go by just filling the tanks and heading down the road.
I had another guy sware by this , untill his water pump broke. It depends on the climate your in. And while blowing out will work 90 percent of the time, its the other 10 percent that gets ya.
Exactly Anti freeze is foolproof, other methods are not
IF you know what you are doing Blow out is 100% effective. I have over 42 years and thousands of RV's I have winterized by using air to blow out and have NEVER had a failure. The ONLY places I install Antifreeze is in the Clothes washer drain pump and the Dishwasher drain Pump which are not connected to the fresh system. Doug
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
