Bobbo
Jun 15, 2021Explorer III
Sjm9911 wrote:LouLawrence wrote:
Don't use anti-freeze next time. Drain the fresh water tank, and black and grey tanks. Use an air compressor to blow the fresh water lines and then just throw a bit of anti-freeze in the P-traps to get rid of or dilute the water enough to prevent freezing. Next year you are good to go by just filling the tanks and heading down the road.
I had another guy sware by this , untill his water pump broke. It depends on the climate your in. And while blowing out will work 90 percent of the time, its the other 10 percent that gets ya.
Sounds like he forgot to drain the water pump. You will always have failures if you aren't thorough. The water pump must be drained separately from blowing out the lines. I know someone who always winterized by pumping RV antifreeze through his system. One year, he forgot to do the outside shower and it broke. That doesn't mean that RV antifreeze is a bad choice. It only means he wasn't thorough.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
