enblethen
Feb 16, 2019Nomad
The correct receptacle is the four pin NEMA 14-50R.
Problem is what is the house wired with. Older homes were wired with 6/3 with NO ground. The ground in the range was jumpered to the neutral.
Newer homes are wired with 6/3 with ground. The neutral and ground have the own wire to the service panel.
I would verify your wiring first, then get the correct range pigtail.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
