landyacht318
Jun 13, 2018Explorer
I was unaware of the Silverstone 140Mm fans, and cannot have an opinion on those specifically, only silverstone as a manufacturer, which is pretty high.
Every time I have places restriction behind a computer fan, and then in front of the fan, the fan seemed much happier and more efective pushing air rather than scavenging it from behind through a restriction.
I have no personal experience with Bilge blowers, and will limit my opinion on them until I do.
Regarding using PWM Motor speed controllers to control fans, one must seek controllers with 21Khz or higher. Many are 13Khz, and will make the motor whine loudly, annoyingly when it is slowed down. I have several 13Khz LED dimmers i used on fans ansd the whining is louder than the fan itself.
Many computer fans will be advertised as PWM fans, or 4 wire fans. These have a blue wire, fed a PWM signal by a computer mother board, which will control the fan speed, but this blue wire can also be controlled by a pwm generator.
One can make one or buy one. Noctua has fairly recently come out with a speed controller for their fans, but it also controls any other 4 wire PWm fan, with the possible exception of Delta PWM Fans.
https://noctua.at/en/na-fc1
I have one of thes controlling my two 3K rpm Industrial Noctuas and at minimum speed both together are something like 0.03 amps and dead silent. max speed approaches angry sikorsky, but when needed, better to have it.
Noctua fans come with a 6 year warranty, and they honor it quickly via an email. Never had something shipped from Austria but it was here in 4 business days. I said 'screw it' when one fan quit, and opened it up with elecrical nippers and saw the microprosessor looked and smelled like its magic smoke escaped. Took pics, emailed them. 7 days later new fan at no cost.
Regarding specs of Silverstone fm181 vs Ap182, I was always surprised that Ap182 was rated at 165CFM and fm181 atr ~150 cfm, considering the impeller is exactly the same, one turns 1300 rpm and the other 2000 rpm.
The AP 182 with the spiral faceplate concentrates the flow into a narrow column. If placed 8 feet away, i will estimate that the 180MM column of air has expanded to a 3.75 foot radius.
The Fm 181 there is no column, just 4 hot spots at much wider angles as there is no spiral faceplate to concentrate the flow. What I can say from experience with both, is th eAP 182 on high speed is impressive, and does not scream like a smaller radius fan.
The FM181 is 700 less rpm, but also 1 amp less at that rpm.. It is amazingly quietat max speed, but its airflow is not near as impressive as the AP182. Again my eye brow is raised a tthe only 15 more cfm rating of the AP182 vs the fm181.
They also have the thinner 180MM silverstone available, not sure of its ID. It has more, smaller fan blades. No experience with that one but it too has speed control and good CFM for the amperage.
If you do get the bilge blower which is wise if you want to run ductwork, I would definitely recommend a 21 KHZ PWM motor speed controller for it, one that you an put or relocate the speed control potentiometer somewhere conveninent, and also use some rubber mounting feet to isolate it from whatever it is mounted to.
The computer fan world is very competitive, regarding noise and CFM and static pressure, and we all benefit from companies like Silverstorne and especially Noctua, for pushing the designs to the degree that they have.
Look at all the tech in their latest flagship model:
https://noctua.at/en/products/fan/nf-a12x25-pwm
Sure one can get many higher rpm fans with impresie CFm specs for the same price as one of these Noctua's , but I think it is impressive one can still find this level of engineering and precision production for less than 30$.
I've got Noctua's everywhere. Fridge Electric cabinet exhaust, Meanwell power supply, Intake fans.
My one silverstone fm121 is my roof exhaust fan, has a counter rotating fan in line below it. An Arctic cool F12
Turning on the arctic cool fan, when the fm121 is on max speed reduces the noise by half and seemingly doubles the airflow.
I tried to feed an 120MM 3Krpm Industrial Noctua this same fan, and it got twice as lousd and airflow seemed to be halved. Os the silverstone stayed on my ceiling and the Noctua pushes filtered air into my rig.
Basically, parked in full sun, with reflecticx window shades on the sunny side, I can keep my rig cooler inside than outside ambinet temps, until late afternoon when the outside can cool quicker than my rig.
I can do this expending just 1.65 amps as my air intake and exhaustm are shrouded. Fans are not simply placesd in an aperture, but have shrouds so their entire volume of air moved, moves once and cannot do a Wuick U turn and pass through fan again, like a small fan in a bigger window can do.
Even with 30 year old door seals, I bet my fans could move a barometer needle
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
