wopachop
Jun 13, 2018Explorer
Would love to see pictures of all this fun stuff. The mechanical thermostat is an option will check it out.
Wonder if i could get power for a fan inside the fridge behind the light bulb. Its your standard 110v/Propane fridge in a toyhauler.
Heres my first attempt at filtered positive pressure. Found a $25 automotive radiator fan off amazon. 12v DC and pulls almost 6amps. Barely pushes any air. Super loud. Like that joke you guys keep making. Not even sure what it is, i picture a small yapping dog.
I dont like how this cardboard shroud has air gaps. It does setup in seconds using a bungee cord. Also dont like how the window is open and shades are up. Could solve those problems with tape but its not ideal doing that every time.
Thinking the 4" Blower mounted under the trailer with an air filter on the intake will be the ticket. PWM dim it and can hook to the batteries directly which have solar charging. I should be able to kill all power to the trailer with the kill switch. Then be gone for weeks or months and not worry about the trailer being really hot inside.
I want to use these mega efficient computer fans instead. But dont want them on a window. Will definitely replace the bathroom vent fan, and also buy a couple to use for indoor circulation fans.
Been hoping to come across that filter sock that was mentioned. Filtering the inside air would be nice.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
