landyacht318
Jun 16, 2018Explorer
I have the 252 cfm Delta screaming banshee 120mm x 38mm fan. There is only one 120MM computer fan more powerful, and Sanyo San Ace, and it is only slightly more so, yet significantly more expensive.
There are some smaller 5 and 7 inch radiator fans which might be in the same power range.
http://www.skycraftsurplus.com/12vdcfanebm6inchdiameter.aspx
https://www.amazon.com/Spal-30103011-Paddle-Blade-Puller/dp/B009OBP0Z6
I was not able to tame its speeds to tolerable noise or power levels either through a PWM motor speed controller, or Via voltage, as below a certain point it just stops, and I measured the minimum speed I can attain at 1.83 amps. Below something like 7.8v IIRC, it stops, and it is still way too noisy to tolerate on an consistent basis at the minimums I was able to achieve.
I could also not get this Delta fan, or my 92MM version to respond to a PWM signal sent on the 4th blue wire.
I did not try it using teh Noctua NA-fC1 speed controller which I got well afterwards. I could have blown up the PWM driver in the fan trying to get it throttled on PWM from PWM motor speed controllers, but there is some info online about an inverted PWM signal required for Delta PWM fans, whatever that means. I gave up ( for now) on speed controlling the Delta PWM fans on the fourth wire.
The Bilge blower might have a setting below of which, it just shuts off.
Regardng computer fans on internal vents, you could split the blue wire from the Noctua speed controller to many PWM fans, and just power each fan from more local wiring, rather than running 3 wires from the speed controller itself to each pwm fan, or having one dedicated PWM speed controller for each 4 wire PWM computer fan.
The silverstone fm series fans with built in speed control, come with 10K ohm potentiometers to adjust that speed,
Knowing that range of resistance, someone more electrical savvy could likely influence these fans rpm according to temperature.
The speed control of fans is pretty key, and so is pure power when volume and amp draw is of much less concern that the fastest possible exchange of outside air for inside air. I love being able to crank 3 potentiometers and feel a wall of cooler air work its way from the intake fans to the ceiling exhaust fan, then dial them down accordingly.
If I could efffectively control that 120MM 252CFm 35.88 mm sstatic pressure screaming banshee Delta fan to tolerable speeds and amp levels, I would be happy to have it exhausting my ceiling, or scavenging filtered from below and forcing it into the cabin. I might do this with a 140Mm industrial Noctua NA-f14 since I know I can just send the blue wire a PWM signal from my existing Noctua speed controller, and 160CFM and 10.51MM of h20 static pressure for 0.5 amps is pretty respectable too.
The bilge blowers are nice, as they are easy to hook ducting to, but I would much prefer some sort high power PWM computer fan that I can throttle to near silent speeds and very low amp draw.
BUt honestly I do not need much more ventilation, I can keep the rig interior as cool or cooler than ambinet, until that brief period in late afternoon when ambient might be able to cool quicker than the rig can.
The cone style auto airfliters on a bilge blower certainly simplifies design.
Consider vibration isolation and sound blocking in your design, rather that trying to attend to those possible issues at a later date.
Keep us informed of your progress.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
