Gjac
Apr 04, 2016Explorer III
SCVJeff wrote:Is this a new burner tube or did you clean it with a wire wheel and reinstall it? That occasional flicker or backfire as you describe sounds like a problem of the air to propane ratio being off. If it is still your old burner and it still flickers after you blow it out again and check the pressure and it is good reread my first post and Wizards post.
I'm getting an occasional backfire out of it. I guess the next step is to blow it out again and maybe find a WC" meter to check pressures
