SCVJeff
Apr 04, 2016Explorer
Gjac: I've had the same problem getting fine debris, in my case likely salt, just inside the burner and that will cause the flame to yellow up, AND pre-detonate the LP in the chamber. That causes it to backfire. The first time that happened I cleaned and scraped, blew it out, and never did get it where I wanted it to be. Its amazing the tolerances on these things. I might build a little mix slider, but at sea level shouldn't have to.
Chris: I'll look at that too, but to be clearer, the flame isn't going out above the burner, its igniting within it and I observe flame coming out the 4 air vents. When that happens there is no reignation spark because the flame never went out. Strange eh?
