dougrainer
Feb 22, 2014Nomad
Dutch_12078 wrote:dougrainer wrote:
A battery will not go dead or discharge unless there is a draw on it. Interstate builds the BEST batteries as far as I am concerned. Any warranty on a battery also is dependant on the price you pay. For instance, I went to the Interstate battery training last week on the new AGM batteries Interstate has developed. There is a BIG difference I found out in AGM batteries. There are PURE LEAD AGM's and all the bothers with use a mixture of lead/alloy lead . Interstate makes both kinds. The Pure Lead are a lot more expensive and carry a full 5 year no pro-rate warranty. The non Pure Lead batteries have a 3 year with a pro-rate. If the AGM does NOT state Pure Lead on the case, it is a lead/alloy AGM. Still good but not as good as a Pure lead. They do NOT make a AGM in 6 volt or 27 series 12 volt yet. You would use the 31 series Pure lead AGM 12 volt in place of any 6 volt's if you wanted to go to AGM's. Doug
Johnson Controls makes many/most of the Interstate automotive batteries, do you know if they make the AGM's as well?
They showed us a Video of the Factory for the AGM's in Alabama. It was an INTERSTATE facility. I never asked WHO or where the other batteries are made. Makes NO difference as the batteries are designed by the retailer and the Factory builds to those specs. Interstate would specify the materials and Auto Zone and Sears and Walmart specify their criteria. Doug
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
