tntcrock's avatar
tntcrock
Wheel Bearing Seal?
Fixing to repack and inspect my wheel bearings? How do I know what seal I need? I've also seen some people refer to a single or double lip. Would like to get the replacement seals before I break a hub down.
  • Bearing maintenance is very easy to do, but you want to make sure you do it right. Be careful getting advice here regarding how to actually repack tbe bearings, ive seen a lot of bad information. Look on line at an actual manual instead. As Hiking said, the seal info will also be in the manual.
  • If it's a Dexter axle, they have a good online chart that will tell you what seal to use. Depends on your axle size, drum size, bolt pattern, etc. Here's the link.
    Get the double lip.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
