rfloyd99's avatar
rfloyd99
Wheel Bearing Temp Question
The axles were recently replaced on my 27' TT, and the tech said the bearings looked fine. I have put almost 20K miles on this since I bought it new 3.5 years ago. I have had the bearings checked twice in that time, and they "looked fine" both times. They have grease fittings, BTW, but I have never added grease.
About a year ago I asked about bearing mntnce on this forum, and the answers ranged from repack every year, every two years, never (just shoot some grease into them from time to time).
Since we are leaving on a 7K mile trip soon, I want to do the right thing.
The last time I used the trailer, I drove 150 mostly highway miles, and 15 minutes after stopping I checked the temperature of each wheel with an infrared sensor. The last 10 miles had been city driving, so the brakes could have contributed to the heat. It was about 82 degrees at the time.
I have no idea if the temps I read are appropriate. I aimed the sensor at the alloy wheel, right at the hub. The readings were:
Right Rear 95 degrees
" Front 114
Left Rear 132
" Front 89
Does this seem normal? should there have been such a range, fr/back, L/R? If so, I will shoot some grease in them and call it good, unless you recommend something further is needed.
Thanks for your help!
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
