How often do you all pack your wheel bearings? My husband is doing it every trip. This to me seems really excessive for a 120 mile drive. I could understanding if the trailer were a boat trailer an...
Once a year as per the Manuf. directions, More than that can lead to problems with too much grease and can get expensive as the rear seal needs to be replaced because if it gets worn can cause grease on the brake linings. If it has the EZ lube fittings on the outside hub too much grease can cause rear seal to leak and throw grease on the brakes.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
