Upon return from the last trip or two, I have found a couple of the wheels have had the dust caps fall off (the cap, with the rubber nipple which covers the hub opening). Found them loose inside the h...
Yes you need them 100%. A hubcap is not any sort of substitute solution. If they won’t stay in, either try another set, or glue em in a bit. Clean both surfaces and use a little rtv or threadlocker or alternatively you could deform the caps a bit, punch a couple dimples in the lip outward to get more of a friction fit. Heat is not a concern. If they get hot enough to burn any silicone or whatever you have bigger issues.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
