RoyB
Jun 08, 2016Explorer III
I do not ever let my Batteries get below 12.0VDC...
This is the approximately 50% charge state and continuing going lower will eventually do harm to your batteries. For us this is the time to stop using the batteries and start re-charging.
Additionally I will not start using my batteries again until they are at the 90% charge. This is approximately 12.5VDC
Charging from the 12.0VDC state to the 90% charge state will take around 3 hours of charging using smart mode charging with the DC Current capacity of 17-20AMPS of DC Current for each battery being charged in the battery bank.
Whenever we would just charge for an hour (quick charge) or so the batteries would start losing their performance and drop to the 12.0VDC state quicker each time. Continuing to do this will eventually do unrepairable harm to your batteries.
The trick for us is to never get into this situation of not having enough battery to do what you want to do...
My four 12V deep cycle batteries were purchased in 2008 and I lost one right away for not charging them properly using a constant 13.6VDC type charger. The other three batteries have done me great up until last year 2015 where one them just would not hold a charge above 12.2VDC for any length of time. This season another 12V battery did not survive my charging to full 100% mode and removing the battery terminals over the winter months. I am down to only one good performance 12V Deep cycle battery at this point and the last battery starting to only hold a charge up to the 12.2VDC level. I'd say not bad for 8 years with an initial cost of $75 for each of the four 12V 85AH Deep Cycle INTERSTATE GP24 batteries.
I am planning on replacing these with two groups of 6VDC Golf Cart batteries in series giving me around 450AHs of capacity for about $450 or four each of the Trojan 12VDC 150AHs T-1275 giving me 600AHs capacity which will cost around $500-$600 if I am lucky... If I can get these to last 8 years than even the $600 would be a good deal... Going with the Trojan batteries will also require me to change out my on-board converter/charger unit for one that produces 14.8VDC Boost charge voltages. That will be another expense to deal with if I want to be able to get from the 50% charge state to the 90% charge in a quick three hour charge time when camping OFF-GRID...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
