EagleScout-USA's avatar
Jun 08, 2016
When the battery runs dead....
Should the battery run down after a few days of dry camping, and the power awning and power slide are fully extended...will plugging into my running truck offer the necessary power supply to retract the awning and retract the slide? I may face this situation this weekend, and want to ensure I am prepared. Thank you.
  • Yes, allow the truck a few minutes to charge the battery some then you can do what you asked. If you have a large Alternator on your truck you can hook up the trailer battery with jumper cables, this will help charge your battery much faster.
    Run the trucks rpm above idle. My HP Alternator in our truck will put a large amount of charge back into the battery bank in a short time.
  • Recharge the batteries for the awning daily, before they get low, in charge, let alone go dead, usually first thing in the morning.
  • Running the batteries that low will reduce their life so they will reach this point sooner and sooner on future trips. If you know that you are that short on battery capacity install better batteries, more batteries, solar, or generator now so you can have the best experience in the future.
  • If all is connected and working as its supposed to, yes.
    But jumpering TV battery to trailer battery, will work faster.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
