tmoo's avatar
tmoo
Where do I find these connectors
My Atwood furnace has been giving me fits. The control board would just buzz and motor would come on. I finally tracked the problem down to a loose connection in the lower wire on the rocker switch on the furnace. The wire has some sort of blue inline crimp connector that is mostly round but incorporates a connector to attach to the spade on the switch. The connector is in the middle of the wire. This connector isn't making good contact and if I work with it the furnace will run just fine.
I need to replace it so I don't have to open the furnace to wiggle it every time it works loose. My question is where in the world do I find the correct replacement connector and what it is called? I could rig it up with a regular butt splice and a tag line with a spade, but really?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
