path1
Jul 01, 2016Explorer
Op here…..
I printed out couple responses and took down to places where I buy parts and showed him. (I still have a couple parts I'm waiting for on another project). Also looked at the cut away display model again. Yes, I’m wrong about a tube going thru the metal. Looks like a hole about size of ball point pen. The display had some parts painted to show how grease was supposed to work going thru the spindle.
Showed younger guy the printed responses he turned around and got his boss involved.
Here is gist of conversation from well experienced guy.
Ex-lube is good product but not as good as what manufactures plays it out to be. Many people buy bearings and seals from auto part houses and they don’t get very good seals or sometimes end up getting wrong size. Some seal are very close in size and hard to match up laying on top of counter top. Always buy “spring loaded double lip” seals by your make and model number of axle. Not the old seal you put on top of counter. If seal is rubber coated, don’t use any gasket material on it. Rotate hub slowly while tightening spindle nut. And put about 50 ft lbs pressure to “pre-load” then loosen spindle nut some, then finger tight.
Me: OK, I got all that. If you were at home doing your axles in your driveway would you hand pack only or would you also use the ez-lube zerk.
His Answer: Not sure because I have never used them.
Me: OK thanks.
My thoughts...Guess I'm thru using the ex-lube zerk and will only hand pack for now on.
:)Sometimes I wish I was oblivious to all the things I've learn about RV's. Our first trailer we got in early 90's we put a ton of miles on it and never had a problems and never worried about bearings, tires. Hosed off roof maybe twice a year, if no water came inside after hosing off the roof, obviously it was OK:).
Thanks for the input...I was under the impression that the Ez-lube style spindles had problems in the beginning when they came out and problems have been solved with newer models.
Me: OK thanks.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
