- First lets get to the correct terminology.
A converter changes 120v A/C to 12v D/C.
An inverter changes 12v D/C to 120v A/C.
Now if you are looking for your converter start by finding you fuse/breaker box. Now figure out how to get behind it or under it. You should find your converter there or very close to there. I have a different type and year of trailer but my converter was actually plugged into an outlet on the bottom of my fuse/breaker box. and the cord was only maybe 2 feet long. - jrnymn7ExplorerBob, do you mean converter?
converter does 120Vac to 12Vdc.
inverter does 12Vdc to 120Vac. - 2oldmanExplorer IIYou won't likely find an INverter. You will likely find a CONverter. Just follow the humming noise.
Wow..your first post in 9 years. Must be a record.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
