Old-Biscuit
Dec 01, 2015Explorer III
HappyCampingCouple wrote:
Thanks Kevin. This is a 2 bedroom park model. No built in furniture. I hear a noise in the bathroom when the water is turned on. The water started working again when I went ouitside and turned the outside water on the hose and turned the main off and on several times. There may have been a clog in the main that I flushed out. Like I said there is no water tanks or black tanks on this model. But what sounds like a pump comes on when the fauset is turned on and slowly stops after the water is turned off. I have no false back wals or floors that open. I see a water line that vibrates when the water is on comming from the floor under the bathroom sink which might be the noise im hearing but I just dont know. I'm just glad the water is working for now LOL :)
No water tank then NO water pump.
You are hearing a supply line vibrating against a wall OR the city water inlet check valve is making the noise
