Lenny_K
Nov 17, 2017Explorer
The only thing that if you get an install done at Discount Solar in Quartzsite insist that your charge controller be set at 14.8 volts for absorption if you are using flooded cell batteries. So make sure that your charge controller has the capabilities of changing set points to enable 14.8 volts.
Discount Solar always insist that you use 14.4 volts which will never get your batteries properly charged.
