MEXICOWANDERER's avatar
Nov 05, 2016
where To Buy Precision Resistors Fast
This is for a 12-position click-click voltage selector switch for the Megawatt. Would love a 400 - 800 ohm spread using 9 resistors incrementally stepped. Also would like referral for a gold plated contact robust switch. .1% 1/4 watt metal film resistors would do fine. Need to order Mon morning and pick up on Friday. Thanks.
  • Mouser ships from Texas, so their shipping should be faster and maybe cheaper than Digi-Key, which ships from Minnesota.
    There's also BGmicro.com in Texas, a great place to check for all sorts of electronic surplus.
    I don't know about 0.1% metal film through hole. The finest I've bought were only 1%. Surface mount, yes 0.1% thin-film carbon resistors - laser trimmed - I use these usually in the < 300 milli-ohm range for current sensing on high power LED drivers
  • Digikey or Mouser would be my recommendation for the resistors. Digikey carries a couple of lines of precision resistors, 1% to 5% in certain lines.
    The stepped attenuator/switch with 12 steps may be difficult as most have more positions. I have a Russian stepped attenuator on the bench, a monster piece, probably from some military application. It's way too big for anything you have in mind.
    OK, found a single deck 12 position switch from Goldpoint. You'll have to contact them about the shipping window. Their products are first class.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
