Take the old seal to a NAPA store. If they can not read a number on the seal I am sure they can measure the seal and get a replacement.
You may have a choice of a single or double lip seal. I recommend the double lip.
The trailers all use the same seal for each axle rating and there are only about 4 different ratings.
My local NAPA store has a section dedicated to trailers and has the seals bearings and lots of other items for trailers.
e Trailer is also a good source but takes about a week for shipping.
I order my seals from e Trailer and keep 6 on hand for the next time I want to do the bearings. Why 6 that is in case I damage a seal while installing or as happened once I installed the seal before the bearing! Maybe a little Alzheimer problem.
I also keep a set of greased bearings (in a zip lock bag)in the trailer along with the seals in case I ever have a bearing problem on the road.
