bpounds
Aug 07, 2020Nomad
Such a rack can be built to handle the weight safely. I see them all the time.
But before you do, think about this. The generator is going to be much more noticeable when running when it is attached directly to the frame of your trailer. You'll hear it more, and even feel the vibration, compared to sitting the genny on the ground a few feet away. It isn't the distance so much as the direct connection. And where is your bed? In many of those smaller trailers the full size bed is right at the rear. Usually they are too short for a front walk-around bed. Yours might be different. And of course, you can tote the genny there and still sit it on the ground when you want to run it, so it may not be a deal breaker for you. Just something to consider. Also consider where the exhaust is likely to waft, relative to any windows.
