bpounds
Aug 07, 2020Nomad
One other thought...don't assume that a receiver has to be in the center of the rear bumper. You won't be towing with it, right? It can be better built if you place it right at the end of a frame rail. You can add a second one on the other side too if you want, maybe for bikes or some jugs of water. You're into customer welding anyway. And some of those thin bumpers fail not at the weld to the frame, but right in the center due to repetitive twisting of the 4" tubing. Frame gussets won't do much for that, but putting the receiver at or near to the frame rail stops the tube twist.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
