Fisherman
Jan 19, 2021Explorer
Maybe some of you naysayers should go see your local high school physics teacher and have him explain what happens when you add weight, not at the pivot point which would be the trailer axle but more likely 7-8 feet behind the pivot point. If it's a 50lb genny, at the axle it would exert 50 lbs, at distance of 7 feet it would exert about 350 lbs, be it down due to gravity or add that amount to sway, something not desirable.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
