klutchdust
Jan 22, 2021Explorer II
okhmbldr wrote:
You might try this test before moving forward. Get a really good scale and position it under the hitch at the ball point then check the tongue weight. Then get a 100# kid/person to stand on the rear bumper. Check the tongue weight. Add another 100# person, check the tongue weight. That will tell you how much tongue weight you will lose by adding the generator/carrier to the rear area. Then you can compensate any tongue weight loss by loading the inside of your trailer heavier at the front to get back to a good balance for your trailer.
I like your common sense approach to this. A lot of thoughts on how adding a generator will affect the tongue weight but no real solutions. I towed a 16 ft. trailer on the rear of my "C'
motorhome loaded to the legal limit and didn't feel any difference in handling, if anything it helped plant the coach firmer on the ground and felt better in the wind. A lot has to do
with what your tow vehicle is also.
