bpounds
Jan 22, 2021Nomad
Fisherman wrote:
Maybe some of you naysayers should go see your local high school physics teacher and have him explain what happens when you add weight, not at the pivot point which would be the trailer axle but more likely 7-8 feet behind the pivot point. If it's a 50lb genny, at the axle it would exert 50 lbs, at distance of 7 feet it would exert about 350 lbs, be it down due to gravity or add that amount to sway, something not desirable.
You might want to see your physics instructor and ask for your money back.
A typical travel trailer (TTT) has about 15% weight on the tongue. 50# added at the bumper would remove about 42.5# from the tongue. That might screw up the handling of some TTT, but that would be rare. A 21' TTT weighs around 6k# GVWR, so you can expect tongue weights in the 900# range. And that's before we complicate the calculations with a WDH.
And all that is before we even consider the empirical data of about 10,000 people out there who have done this exact thing. Hell, my trailer even has a roll-out tray at the rear for cargo. I think it has a 200# rating IIRC.
