Gdetrailer
Jan 29, 2021Explorer III
bpounds wrote:Fisherman wrote:
Maybe some of you naysayers should go see your local high school physics teacher and have him explain what happens when you add weight, not at the pivot point which would be the trailer axle but more likely 7-8 feet behind the pivot point. If it's a 50lb genny, at the axle it would exert 50 lbs, at distance of 7 feet it would exert about 350 lbs, be it down due to gravity or add that amount to sway, something not desirable.
You might want to see your physics instructor and ask for your money back.
A typical travel trailer (TTT) has about 15% weight on the tongue. 50# added at the bumper would remove about 42.5# from the tongue. That might screw up the handling of some TTT, but that would be rare. A 21' TTT weighs around 6k# GVWR, so you can expect tongue weights in the 900# range. And that's before we complicate the calculations with a WDH.
And all that is before we even consider the empirical data of about 10,000 people out there who have done this exact thing. Hell, my trailer even has a roll-out tray at the rear for cargo. I think it has a 200# rating IIRC.
bpounds, you might need to hit the physics books yourself.
50 lbs on a TT bumper will not remove anywhere near 42.5 lbs from the tongue.
I actually HAVE done this as an experiment for my 100lb gen. I put 100 lbs of concrete blocks on the rear bumper and measured just under 1/3 of the 100 lbs being removed from the tongue (30-32 lbs).
For myself, I would never notice 30-32 lbs missing from a tongue weight of 850-900lbs when loaded (which is at 15% TW)
Has to do with the location of the pivot point and a TT actually has the axle placed approx 1/3 the way from the rear bumper, 2/3 the way from the tongue..
Longer trailers have more rear "overhang" but they also have more distance from tongue to pivot point at the axles..
Think of it in the terms of a playground teeter totter..
It is all about maintaining 10%-15% tongue weight..
You can also use a bit of math to figure it out also..
For more in depth material, Dexter axle has a lot of good detail and theory for axle placement..
In the end, I scrapped the idea of carrying the gen on the back of the trailer and it had nothing to do with tongue weight or even frame damage.. More practical sense since running a gen is going to be loud, gen will transmit every vibration to the trailer frame and box and then there is the Carbon Monoxide issue to deal with..
I would rather not have a gen that close to my trailer operating for the noise, the vibration and Carbon Monoxide poisoning.
As they say, three strikes and you are out..
