MEXICOWANDERER wrote:
Keep shunts, buss bars, fuses and breakers as far away from a flooded battery as possible.
Agree. All batteries (but especially flooded lead acid) give of vapor that will get to corrosion on most metals.
The contact point to the shunt's metal should be mirror bright then a coating of NON PETROLEUM BASED sealer applied over-top.
While I would agree a silicone dielectric grease is probably best, but why the heavy emphasis on non-petroleum ?
The shunt's milliamp wire terminals should be soldered.
Picking a nit, the metering device at the end of those wires is actually measuring millivolts. The amount of current passed is probably in the microamp range.
