JRRNeiklot wrote:
Those instructions say all negative loads should go directly to the shunt. I am currently using the stock power cables from the trailer and they are ran directly to the battery. Is that going to be an issue or can I leave those as they are?
Everything else I can wire to the shunt fairly easily.
Thanks.
Your existing wires stay in place. The shunt should be installed between Battery (-) phase battery post and frame ground. Look to see where your (-) phase battery wire attaches to frame ground. If the negative cable coming off the battery goes to frame ground, it is often easier to attach the shunt at the battery or a short distance away between battery and that negative cable that connects to the frame.
