TomG2
Apr 15, 2019Explorer
Which 12.0 volt?
"Everybody" says to not drain 12 volt batteries below 12.0 volts. Operating a small refrigerator drops the apparent voltage to 11.9 volts which recovers to 12.5 volts between cycles. Too low or can ...
TomG2 wrote:Yes that battery seems too small for the load.time2roll wrote:
I think you need a second battery. How long was the fridge operating before you get to 11.9 volts?
Never actually got below 12.2 volts but I used 11.9 to keep it simple. This was with a little 35 ah agm battery that I was evaluating. My posting was to verify that people use resting voltage and not loaded voltage to determine cutoff point.
